Release Journey 1.3.0 is out
Gwendal
Developer
Verified licence
4 add-ons Classified Emporium Client Plans XenStreak
Journey 1.3.0 is the current stable release.
Turn first-time visitors into loyal members. Automatically.
Grab it in the store, talk about it in its dedicated forum, and post your ideas in Suggestions.
Journey 1.3.0 is ready, and it is a big one. Here is everything that shipped since 1.2.0.
New in 1.3.0: per group journeys.
Every step can now be restricted to specific user groups. One board can run several journeys side by side: a newcomer path for your probation group, and a separate set of milestones with their own rewards for veterans. Steps left on "All members" behave exactly as before, and every existing step is treated that way on upgrade. The restriction is enforced everywhere, not just in the display: a member never sees a step reserved for another group, never gets a progress row for it, and it never counts toward their journey completion.
Fixed in 1.3.0.
  • Journey notifications used to show a grey question mark instead of an avatar. Alerts are now sent as the member, so their avatar shows up like any XenForo alert.
  • Step and journey completion notifications were never sent: they were gated behind options that did not exist. All three options now live under Options, Journey, and the Newcomer group feature finally runs as documented.
From 1.2.2: DragonByte Credits 6.x compatibility.
Boards running Credits 6.x hit a fatal error in the Credits admin because our event triggers were built against Credits 7. The handlers now check before declaring themselves: on Credits 6.x everything in Journey keeps working, and currency rewards simply wait until you upgrade to Credits 7, with the step editor saying so explicitly.
From 1.2.1.
The admin control panel entry is now a top level tab of its own, with proper phrases for its navigation.
The update is free for every license with active updates, as always. Grab it from your store account and tell me what you build with per group journeys!
